Background info: I'm burning through a pound of beans every 2-3 days trying different suggestions from the forum and playing with the dose and grind. I've read Scott Rao's book and I think I've got the basics down. So now it's time to receive a little criticism.
I've been using a variety of beans from Intelligentsia / CCC / PT's / and a local roaster. Doing my best not to exceed 8 days old on the beans, but mail order during the holidays can be a little harrowing.
I lowered the PStat to .9 per Stehano's recommendation in multiple posts.
My process: I fill the boiler to about 80% of the sight-glass. After a dry pull to heat the group and PF, I use the double basket and dose at ~15g (about 9s on my Vario). I groom with the side of my finger and use a very light tamp - 10 to 15 lbs or so - to level and then a quick polish. Once the PF's locked in place I pull until I hear water running just a bit and give it a 5 count to preinfuse. Then the lever goes all the way down and I give it about 10 seconds or until I see the first drops. I slowly raise the lever to about halfway (I have to keep slight pressure applied on the first pull - normal?) and then give it another slow pull down. After another 3 count at the bottom I can usually let it go. Around 2/3 of the way up, the stream (more often than not) starts to blonde and I remove the cup. I'm producing around 1.75-2oz per shot. It's safe to say that 3 out of 5 pulls are underextracted and sour, one is excellent (for me), and one is bitter.
There was a remarkable difference in taste after I adjusted my Pstat, but I'm still not sure if I've got the grind all figured out - which leads me to believe that I don't. However, every time I try to grind finer than my current range of settings, my pucks turn out soggy and rather disgusting.
So my first questions:
What should the puck from a good shot look like when it's spent? Should it come out in one piece?
How much do you dose for the double basket - and do you use the double pull on the lever?
If the shot is under-extracted but the puck is soggy, is that an indication of high dosing?
Do you turn off your machine between shots to preserve the temperature of the water? Is this as critical with the Pstat lowered?
As beans get older, the grind needs to get finer?
Reasons for the sour shots?: Since (I think that) my grind is about as fine as it should go, it seems to me that I might be dosing a bit high or that the temp is too low (I turn the Elektra off between shots). I'm not sure how much more I can adjust the duration of the pull - the whole process is around 35-40s before the shot blondes. Since the shot is blonding but still sour, is the dose too high?
What do you guys think? All comments and suggestions are immensely appreciated.
