Bar: A unit of pressure equal to one million dynes per square centimeter.
Dyne: A centimeter-gram-second unit of force, equal to the force required to impart an acceleration of one centimeter per second per second to a mass of one gram.
PSI: Pounds per square inch.
Conversion...
1 Bar = 14.50377 PSI
9 Bar = 130.534 PSI
Mechanical Advantage (MA) for a lever = Distance of the effort arm (De) to the fulcrum divided by the Distance of the resistance arm (Dr) to the fulcrum.
MA = De / Dr
On a lever machine, the point where the lever end pivots at its attachment point is the fulcrum.
The resistance point is where the lever attaches to the piston shaft. So on a Povoni, the measurement of the resistance arm is from where the piston shaft attaches to the lever back to where the lever attaches to the pivot point. The measurement of the effort arm is from the end of the handle back to where the lever attaches to the pivot point.
NOTE: For the calculations used here, I measured the handle of the Pavoni but the principles apply equally to the Olympia.
Distance from end of effort arm to fulcrum: 10.5 inches
Distance from end of resistance arm to fulcrum: 1.25 inches
If you measure based on grabbing the lever handle at the very end, then the Pavoni has a mechanical advantage of 8.4.
Effort force required to move a given resistance using a lever = Resistance force (Fr) multiplied by Dr divided by De (as described above)
Fe=Fr x Dr / De
In this case the resistance force (Fr) is the desired force on the piston. Our target is 9 bar so we need to see how hard you would need to push on the lever to get this kind of pressure on the piston. Remember that you have a mechanical advantage of 8.4. This means that your pushing force is multiplied 8.4 times. Note: If you choke-up on the handle (grabbing it closer to the machine) then you will decrease your mechanical advantage.
So far this sounded like I had the answer... but my brain keeps telling me I'm missing something. What I have done is figure out how to see how much force is exerted on the piston shaft. I haven't actually figured out how much pressure... (Force and Pressure are different) pressure is force per area. What is the area of the piston? I haven't removed the piston before but based on the size of the dispersion screen and the filter basket I estimate that the piston is about 50mm or roughly 2 inches in diameter.
Area (A) of a circle is: pi times radius squared. So if the diameter is 2 inches, the radius is 1 inch. Thus the area of the piston is approximately 3.14 inches. So that means I have to divide the applied force (in pounds) by the surface area (in square inches) to get PSI (pounds per square inch). Throw in a conversion from PSI to BAR and there you have it.
Whew! Tired of reading yet? Me too. Lets get down to brass tacks.
If you grab at the END of the handle you need to push down with 48.79476
pounds of force to get 9 bar on the piston.
If you grab in the MIDDLE of the handle you need to push down with 56.92722
If you grab at the TOP of the handle you need to push down with 64.04313
There are a few variables here like the exact piston size, exactly where you grab the handle - how long your handle is compared to mine etc. but you get the basic idea. Remember there is NO WAY you will be able to apply this much pressure unless you have your grid and tamp adjusted right.
I hope this helps and if nothing else perhaps it will inspire you to start working out so you can pull a decent shot. Or maybe pulling a shot is actually exercise... Cancel my gym membership???
I'd like to know your thoughts on this.
I've also made some modifications to my steam tip for milk steaming frothing and foaming. Check out my other post on this subject. I made several extra single hole tips if anyone wants to trade for some of your favorite fresh espresso coffee beans.
