I just received my Bruni Brunella:
It seems to be in very good condition, but there is minor corrosion in places from sitting from what I presume to be many years of inactivity.
While taking things apart to clean them, I noticed a spacer behind the lever roller:
It stuck to the roller when I removed it. A whitish substance was left at the end of the roller track—I presume it was either glue or grease that had long ago hardened. It was stuck to the roller with a thin coat of grease, so my guess is that it was not stuck to the back when I got it.
This is the piece after being mostly cleaned:
This is how it looks in the cleaned assembly:
The effect of having this little piece of aluminum is that the lever stands slightly less vertical when parked. It also limits the downward travel of the piston shaft a few millimeters. My guess is that it was intended for the former purpose: Without that piece, the lever appears as though it will touch the reservoir lid, forcing it up a bit beyond sitting snugly on the base. When I got the machine, the lever stood just a few millimeters below the lid cutout. It looked nigh-on perfect.
Do any other Brunella owners have one of these aluminum spacers?
