Broken lever off new La Pavoni Europiccola
Postby rawman on Fri Feb 22, 2008 1:45 pm
As I mentioned on another post, I recently got a La Pavoni Europiccola. Per the recommendations in that post, I ran it with some baking soda to descale it, then let it heat up with clean water a few times to rinse it out, then tried to pull a few shots. I hadn't gotten a real tamper for it yet, so was just using the POS plastic one. The first shot was extremely watery and blonde. Sink. I adjusted the grind finer, next one was also watery but not as bad, still not drinkable. I tried a few more than turned it off for the night. This morning tried another shot, still watery, so ground finer, and tried again. It took a lot of force to pull the shot, but it actually came out not bad.. nowhere near perfect but getting better. however I noticed the lever was not at the same angle it had been earlier. When I lifted the lever, it broke off. I didn't think I was pushing down on it THAT hard. Has anyone broken the lever off a machine like this? Could mine have been defective, or did I just use way too much force and kill the thing? How likely is that to happen?
rawman
Postby ntwkgestapo on Fri Feb 22, 2008 2:37 pm
I have a Gaggia Factory (La Pavoni Pro with a few visual differences. Mechanically the same). I also weigh about 260libs. I've NEVER gotten my Factory to the point where the lever bent or anything LIKE that! I HAVE "choked" the machine once (pushed down with MUCHO force and was unable to get ANYTHING out of the P/F spouts. Twas probably pushing down with well over 100lbs of downforce.).
I'd have to say that, more than likely, something's wrong with your machine...
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
ntwkgestapo
Postby rawman on Sat Feb 23, 2008 3:48 am
Thanks, I appreciate the feedback. I hope WS takes it back.
rawman
Postby oofnik on Wed Feb 27, 2008 7:58 pm
:shock: Never heard of that happening before. Where exactly did it break? Did one of the rolling pins snap? The U brace? Or the actual lever arm itself? That's very strange, and definitely a manufacture defect.
oofnik
Postby mbach on Thu Feb 28, 2008 12:26 am
My very old La Pavoni pro's lever broke. The U bracket was attached to the post by peening / mushrooming the piece that went through the hole in the U bracket. I had a guy weld it. He could have done a better job, but it was free.
mbach
LMWDP #037
mbach
Postby rawman on Sun Mar 02, 2008 1:25 am
Mine broke where the lever bar connects to the hole in the U bracket. It came completely out.
LMWDP #189
rawman
Postby shadowfax on Thu Mar 06, 2008 2:12 am
I have a la pavoni pro as well. It's 20 years old and the lever handle appears to be stamped to the U bracket as others have described. It's taken a lot of pushing from me and is still totally fine.
A buddy of mine has a Europiccola that is the millennium edition. He snapped his lever exactly as you just described about 4 months ago. Like others have said, he took it to a machine shop in Houston and aguy welded it together for $10. It sucks, but I would say be ended up with a much sturdier lever than if he had replaced it with a new lever.
Nicholas Lundgaard
shadowfax
Postby northerndancer on Thu Mar 20, 2008 10:25 pm
I just had the same thing happen to me. New machine, no more than 15 pulls, some of the difficult variety but nothing that should separate the lever from the u-bracket. Today I just pulled the two pieces apart. I suspect that the peening is pretty inconsistent - handmade or assembled as these things are. I will resist my urge to send it back. I think in the long run a small weld will add "character" to the machine. This is how legends are born...
By the way, this is my first post to this forum. I lurked here for a few weeks, trying to decide on which lever machine to buy. After being lured in other directions I came to realize that I wanted to be able to practice something (making good espresso with a quirky machine) that was relatively inconsequential to the meaning of life.
northerndancer
