So, on to the Export...
We were looking to get an espresso machine for the home, and
Here it is as delivered. Not bad shape, though missing the portafilter, top trim pieces, and one foot (as advertised). A bit grubby, perhaps, but nothing a good scrub wouldn't take care of. The inside of the boiler looked clean, though, and the case and base were in fine shape with no rust and few nicks or scratches.
I did get it filled with water, flipped the switch, and was able to run steam and hot water out of the appropriate places. Looking good so far.
At this point I turned my attention toward the show screen, gaskets, and piston.
While the water had come through the shower screen, it was a bit drippy and uneven. I sourced some Craftsman gasket picks from Sears (about $10) and was able to easily pull off the screen and the gasket. Unfortunately, no photos of the mess inside. Just a lot of grime on the inside of the screen and the face of the piston. The filter gasket, however, looked to be in great shape.
I'd guess this particular Sama had been well used and cared for, but at some point put away, and at that point anything not physically attached got misplaced.
Anyway, I cleaned up the dirty bits with hot water, a fine needle, and a scrub brush. Here are the results.
