Sneaky
Our 1 group Bosco demo machine is somewhere in the bowels of DHL's empire, with some luck it will arrive this week in one piece. You are welcome to come down and give it a whirl when we get it set-up.
Bosco are small family firm in Naples that have been making these lever machines since 1950. As with other lever machines they do nice things to single origin espresso, i.e. they open it out and allow you to taste the subtle elements in the bean. You can dismiss this if you like, but i think its worth trying it first.
We like the simplicity of lever machines and are of the heretical view that espresso by numbers has reached its zenith. We think its time to develop a feel for what you are doing with the machine. Time will tell if we are correct. I am unable to provide a scientific explanation why a lever beats an electric pump, but our taste buds think it does. Linear pressure and temperature throughout the extraction is clearly not optimal in the manner it was sold to be.
For example, there is a marked difference between the quality of the espresso from an Olympia Cremina and an Olympia Maximatic. If you are shown how to use a lever they do not need to be intimidating or inconsistent. If you are used to the Cremina you will find the big spring lever almost 'automatic' in nature as it obviously regulates the extraction for you which improves shot consistency enormously. If you paired it with a doser-less electronic grinder I cant see why you would struggle.
I will make enquiries about the gas conversion kit for you with Bosco as I have not yet seen this in operation.
If I talk very nicely to Roberta Bosco I might even persuade her to join H-B and you can have your questions answered at source.
Please find images showing the group cap finish (not our machine) which has now been brought in-house so I don't see this being an issue going forward, and also a close-up of the boiler weld (our machine) which admittedly wouldn't win many prizes at Pebble Beach, but does it need to?
It does however make first class espresso. The engineering is simple, robust, reliable, and easy for anyone half mechanically inclined to fix. This means less downtime and that means better trading results. For most commercial operators that is quite important. If you need more please ask.
Reiss
LondiniumEspresso.com
