Group is the same as most all old Faemas....seals still available...takes a W on the bottom and a V ont he top but be advised......the group demands lubrication about once a month and if you hear rubber squeaking then get out the lube sooner and not later...pull the piston and lube the seals and cylinder since the lube skates off during the pulls and wears the top seal faster than the bottom...this causes water to creep into the group above the piston and rust the spring...you don't notice it since it evaporates while hot. The HX requires constant line pressure to work so while the machine is sitting idle but under line pressure water can pass the seal...particularly when the machine is cold but still has line feed to it. Another needed bit is a line pressure regulator to keep the feed at about 1 to 1.5 bar or you will get extraction at line pressure on the first part of the pull. The Faema seals are classic Italian rocks and are not high temp rated so keep a pair and a spare. I learned this all the hard way
