by peacecup on Sun Sep 04, 2011 9:27 am
I've heard reports of squeaks from other machines, home and commerical. Use of 111 not withstanding, I believe that water is an important lubricant in itself. With home levers that are cooled off after each use I suppose the seals remain damp if used daily. With the Strega, if you are leaving in on 24/7, but not using it 24/7, I wonder if the group heat would be enough to dry out the seals overnight?
PC
LMWDP #049
