by linnaen on Sat Oct 01, 2011 6:16 am
I picked up a Bezzera Family Lever while on a trip back to the UK, and have imported it back to Australia with me.
To export it, I had to disassemble the piston from the group head (luckily easy on this machine) to get it to fit in the boxes with enough space to give it some padding.
A good few months have passed, and I finally got it to Australia, and tonight tried to reassemble it.
First problem: I dropped the piston and there is a bit of a ding on its edge! Will this cause problems with operating the machine?
2nd problem: I put it back together to test if the damage had caused any problems. Filled her up, turned her, bled off the false pressure. Steam fine, water dispenser fine.
However when I tried to flush the group, nothing. As I know that they need the water to lubricate the piston, I stopped there as i didn't want to cause any more damage. I have now turned the machine off, and am waiting for it to cool down to see if I have a blockage somewhere.
There is a little screw on the grouphead on the boiler side (rather than the piston side) and if i unscrewed that slightly water dripped out of there.
Is the damage I caused to the piston going to be a major issue? And if so, could it be repaired, or should it be replaced?
And if i can't find a blockage in the passage to the group, any other ideas what I should look for?
