This is about a sort of a backflush for Big Old Lever machines
I have found that I don't want to remove the three dispersion screen screws very often on my lovely old Conti. She is a bit overweight and I am a bit of a klutz. Here is my solution to the problem.
So: See the photos
1. Cut a disk/cylinder from a large DRY cellulose sponge. It will be too sloppy to do so if it is wet. When wet,the sponge should be about twice the height of your deepest basket.You can get more peace of mind if you poke a thin paring or eXacto knife blade through the sponge in a couple of places.
2. Soak the sponge in a strong mixture of your cleaner of choice.
3. Place the soaked sponge into your basket and portafilter. This also flushes the gasket as the PF is locked into place.
4. Since my machine is plumbed in, I can run water through the group with the machine off. If you can not do so, just turn the machine off when it comes to temperature.
5. With the machine off, but warm, lock the saturated sponge into the group.
6. Let it set a bit. Like 5 minutes,
7. Pull a shot or two through the sponge. Cellulose sponges have open pores.
8. Take the portafilter and sponge out of the group.
9. Use some of the liquid to clean the group gasket and drip tray.
10. Run more water through the group and portafilter. Either turn the machine on or, as in my case, flush it with the pump from the 5 gallon bottle.
When you again bring the machine up to temperature, pull a couple of shots to assure the group and the portafilter are rinsed clean also.
This also does a nice job of de-gunking the passages in some enclosed passage portafilters.
Thanks for the time. I have used this on other lever machines also. Think before trying it! You will be exposing yourself to some very hot water and / or steam. The piston may become a bit sticky afterward, but mine have loosened after a couple of shots.
Cheers
Richard / espressme
PS, If anyone one has a reason not to use this method, Please Post!
