by allon on Tue Nov 01, 2011 8:53 pm
I had to hack a vacuum breaker into my machine, since it didn't come with one.
First, verify it IS the vacuum breaker. If it is, remove the breaker, soak it in vinegar or descale solution, reinstall. Not that hard, actually.
If you want to run without a vacuum breaker, you just have to bring the machine up to pressure, then open the steaming wand to let the air pressure out, 'til you get some good steam, then close the steaming wand, and you're good until you turn the machine off.
The p-stat on mine is a standard Sirai - back left, have to remove a small screw to get the big cover off, then a big slotted screw with arrows showing which direction is + and which is -
Good luck!
LMWDP #331
