Arrarex Caravel wet puck??
Postby vintagelever on Wed Nov 24, 2010 12:26 pm
I have recent acquired a very nice Arrarex Caravel from Italy and have have pretty good success with my pulls...however I notice that there is always a very wet puck with water in the top of the portafilter when I take it off after a pull. Is there a leak somewhere?
vintagelever
Postby Ben Z. on Wed Nov 24, 2010 12:45 pm
I think that's just kind of how it works. You can do a bunch of short pulls after pulling the shot to dry out the puck if you want, but I don't even bother anymore.
Ben Z.
Postby newmanium on Wed Nov 24, 2010 12:45 pm
Completely normal, you just need to pump the handle after your shot to drain all the remaining water out. I typically do this, then let it sit for about 30 seconds, and it's nice and dry.
Lift up just enough to feel the water drop under the seal, not enough to refill from the reservoir. I get enough water for almost a second shot, but if you taste it, not very tasty :P. I assume this is just to do with how the piston system was designed, not all the water is squeezed through the puck on the first pull.
newmanium
Postby lifeandpeace on Sun Dec 12, 2010 8:38 pm
Depends on how you pull.
For my single basket, I pull a single "Fellini"--about half way down--then finish with one full pull. Always a dry puck.
LMWDP #303
lifeandpeace
Postby peacecup on Mon Dec 13, 2010 4:09 pm
I also use a fellini - lift, half-pull until I see a drop fall into the cup, then a slow rise and full pull. The pucks are always dry and firm - they pop out whole. I actually air-dried 4-5 once to test extraction rates. 16g of coffee always yielded 13g of dry puck - remarkably consistent.
I always pack the basket right to the top, i.e. no headroom at all. That's how I get 16g in the basket, although this depends of the roast as well.
PC
LMWDP #049
peacecup
