The Arrarex Caravel - Page 206
- redbone
It does come off but first you must remove the "C"-clip using a c-clip removal tool. Use search engine to find one. I have both a VAM and early Caravel which I've used the tool with.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- grog
If you have a first gen VAM - the 1.0 without a hole in the face of the piston - it does not come off. There's no tiny inner o-ring hence no need for a circlip inside there.
You might have to get a seal set from OE or the non-silicone ones from Francesco and install one of those on the top seal position. It will be kind of a wacky hybrid but should work.
LMWDP #514
- redbone
Here is a link that Francesco Ceccarelli has posted on his site regarding seal replacement.
http://www.francescoceccarelli.eu/Faida ... ni_eng.htm
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
- redbone
Could you also provide the outer diameter (including rim)?redbone wrote:Arrarex tapered basket dimentions at top and 5mm in depth.
Excuse the inverted shots.
- redbone
- grog
Has anyone successfully removed the piston body on a 1.0 VAM? I'm referring to the earliest versions with no hole in the piston face.
LMWDP #514
- Eastsideloco
In case any of you Caravel owners are interested, I created a funnel for it. More info here: Funnel models for 3D printing
Since I saw a request to keep the 3D-printing discussions out of this thread, I invite you to comment and ask questions in the thread linked above.
