The Arrarex Caravel
A haven dedicated to lever espresso machine aficionados.
Link to "The Arrarex Caravel"by peacecup on Fri Jan 04, 2008 10:07 pm
If you search the forums for "Caravel" you'll find several threads that discuss these antique Italian home lever machines. In this thread I'll attempt to link to these others in a general discussion of the Arrarex Caravel, their use, and the exquisite espresso that they produce.
As I mentioned recently in hbuchtel's "Caravel tamping" thread,
http://www.home-barista.com/forum...tamping-t3637.html
a very lovely 1960-ish Caravel arrived in Juneau just in time for Christmas. I've been enjoying at least as much as my new socks :oops: , and today it made the move to its main home, the office. Thats it, in front of a forlorn Estro Vapore, and next to the Dell:
As I ramp back up for work after the holidays, I expect to be doing a lot more brewing with this machine. I'll have a look over the older threads to link to some of the photos of the mechanics, but for now let me just say that this machine is a masterpiece of functional simplicity and design beauty. It is rather on the far left end of the technical spectrum whose right end is anchored by the mighty G-3. I suspect within its limits (7-9 g solos espresso) it is the equal of that long-awaited home-espresso Holy Grail, but even if it can't quite compare to its most distant relative, it still makes a damn good cup:
Thus far I'm just finding out how she likes the grind, dose, tamp. I have experimented very little with different coffees, but have found lighter roasts to be tastier, as might befit a daughter of Milano.
Its great to have a machine that is completely dedicated to solo espresso; no milk here please, but great little drinks any time of day.
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by hbuchtel on Fri Jan 04, 2008 11:16 pm
Thanks for making this topic PC!
I took this video a couple days ago when it was sunny-
[youtube]http://youtube.com/watch?v=j8BxTZOSVjc[/youtube]
The lever went up (opening the valve to the kettle) at about 6 seconds, and the pull started at about 13. First drips at 19.
I usually use more pressure then I did here, which makes a shorter darker shot.
PC, are you doing double pulls like on your P.V.? Or lungos like Timo mentioned? I really like the one pull style... so easy and simple... and I love the gradual build up of resistance and slow release under my hand. Quite a sensual experience! (not to be confused with sexual ;) )
Henry
LMWDP #53
hbuchtel
Link to "The Arrarex Caravel"by mogogear on Sat Jan 05, 2008 1:57 pm
Hurray! For Henry's video and to see the Caravel perched on Jacks work desk! Jack, you can buy an adapter that will allow you to plug the machine in to 110v- but it will be a slow heat up process and I am not sure you will get to full temp....Have fun with that thought...
I bet your co-workers are always amazed at your dedication to not only Salmon but Espresso as well :shock:
I am sure you have found that the basket "screws " into the PF slightly... and that the diffusion screen is affixed to the bottom of the cylinder. I don't think it is removable.
Lastly I did check at my local Radio Shack and they checked at the Radio Shack affiliate in Juneau to see if the voltage converters we had spoken about to allow the Export to function in Sweden are in stock....
I look forward to reading more on your Italian "blonde" getting back to work!
Ciao!
greg moore
Leverwright
LMWDP #067
mogogear
Link to "The Arrarex Caravel"by peacecup on Sat Jan 05, 2008 5:53 pm
S-U-N-N-Y? What does that mean? We are now finally experiencing increasing daylength, but its still dark from 4 PM until 9 AM. And in Juneau, its usually cloudy as well as dark. Its like living in a dream. I wonder why I drink so much espresso in the winter?
Yes, this Caravel is the same that mogo imported a while ago:
http://www.home-barista.com/forum...?highlight=caravel
It is due to his generosity that I'm able to enjoy it. And, as I said, its amazing. I do have a plug converter, so I'll try it on 110 next week. So far the pour-over method is working fine.
The dispersion screen on this one does seem to be attached, but this is no problem since the entire piston assembly is easily removed, and the cylinder can be cleaned from the inside (someone posted a phot of this in an earlier thread, and I need to find the link and post it).
The screen barely sticks out from the "group" (its steel, not brass, wiht no heat sink properties needed). This means the basket requires VERY little headspace, so I can cram it very full, which, contrary to the "downdosing" fans, is my wont. As KS noted in the Smackdown thread, the Ponte Vecchio is also very forgiving of overdosing.
And even in 1960 someone figured out a way to keep the basket in the PF, as mogo notes. Very handy for cleaning, but I still prefer to dose with the basket off the PF, probably because it works best with the hand-grinder.
I'm having so much fun with the Caravel that I'm re-discovering the single basket on the Ponte Vecchio- just pulled two solos on the PV, the first of which was just ok, but the second was...well...a perfect compliment to the winter sun that is shining very low on the miday horizon here in Juneau...
THANKS AGAIN GREG!
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by peacecup on Sat Jan 05, 2008 6:02 pm
Walter's thread has a lot of good photos of the pistons, etc., and some good observations on the Caravel:
I note from my own responses on the old threads that I've always had Caravel envy. Maybe even worse than Cremina envy. If that's possible...
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by peacecup on Mon Jan 07, 2008 11:07 pm
A new batch of Café D'Arte, and some time in the office have combined to allow me to be a little too close to the Caravel today! I remember it was difficult to resist pulling too many shots when I first got the Ponte Vecchio, but the Caravel seems to be even more tempting.
Firstly, I plugged it right into the 110 V outlet with just a plug converter. It heats up to boiling no problem, although it takes a while if the boiler is full. Since I'm only pulling one shot at a time (~15-20 ml) this is not a problem. I hope running it on 110 for a couple months won't hurt it.
Second, I'm now trying to figure out how to control brew temperature. So far it seems that pulling the shot right as boiling begins is working - I may experiment with letting it come to a rolling boil, then turning it off and waiting 1 minute.
Third, I was tending towards coarser and coarser grinds to get the type of faster flow similar to the Ponte Vecchio. This did not seem to work as well, and the last shot I pulled was ground a little more finely, and seemed to bring back the better flavor and crema I'd been getting before.
I'd like to hear how others run the Caravel. This is going to be a fun week.
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by peacecup on Tue Jan 08, 2008 10:55 pm
"There is nothing more stimulating than a case where everything goes against you." - Sherlock Holmes, Hound of the Baskervilles
Well, today's Caravel experiences were stimulating, although not everything went against me:
"We have not yet met our Waterloo, Watson, but this is our Marengo,for it begins in defeat and ends in victory" Sherlock Holmes, The Adventure of the Abbey Grange
I did get off to a shaky start, with a shot of Café D'Arte's Fabriano, their alderwood-smoked espresso blend. This blend needs to be brewed right on, and it wasn't, perhaps my worst shot ever on the new Caravel. The next few were the more reliable Firenze, and the got consistently better, as I tightened the grind and learned not to pull quite so hard. I'm discovering that the Caravel likes to be pulled gently, and therefore, if ground finely, it is pulled slowly. The last shot I went back to the Fabriano, and this time it was finely-ground, slowly-pulled, and it brought out all of the subtle smoky flavors beautifully.
Also today I discovered that the thermostat works very nicely - its just a steel spring that expands as it heats, and turns off the element manually - Walter described it in his "Flea Market" thread.
I also had the very small O-ring in the center of the piston fail during a hard pull. This allows brew water and pressure above the piston. I repaired it, but the O-ring is cracked and will eventually need to be replaced.
The Caravel has three pieces of rubber inside the piston assembly - two O-rings, which I hope will be easy to find, and one piston gasket, which I suspect may be more difficult. Has anyone ever found a source for Caravel gaskets.
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by hbuchtel on Wed Jan 09, 2008 1:25 am
Hey PC, I also had a problem with the little o-ring in the piston- I cut a new one and have replaced it twice. The other o-rings in the piston chamber (different in my model then in yours) were also replaced (Timo sent me some that he had made for his Caravel... no idea how he managed to get them made!).
I'm with you about the slow pull+not too much pressure. My experience in the last two days seems to indicate that using very little pressure in the last 1/4 of the pull produces a particularly soft mouthfeel for the shot... I'll try again this afternoon.
Here is what I'm getting-
First 1/4 no resistance
Second 1/4 slight resistance, sudden build up towards the end
Third 1/4 high resistance, bringing the lever almost to a standstill... gradual release under the weight of my hand
Last 1/4 lessening resistance, requiring a controlled release to slow down the extraction
I was trying something new today- I cut a small tin disk to act as a (leaky) blind basket- this way I can fill the chamber with water before the shot to make it as close as possible to the temp of the water in the kettle. This is intellectually satisfying, but I don't know if this extra effort is going to make the espresso that much better! Only time will tell...
Henry
LMWDP #53
hbuchtel
Link to "The Arrarex Caravel"by mogogear on Wed Jan 09, 2008 1:57 am
JAck,
With reference to the o-ring in the center. The old original one was pretty deteriorated and brittle when I got the machine. I sourced the o-ring that failed you at a local hardware store. I think I have a few. It just sits in the recess in the center of the piston and is held in place by the pressure of the movable lever part. If that makes sense. I can mail you some backups if you don;t find anything close at hand.
I think in my memory that this seal was actually more of a rectangular cross section as opposed to round. This is only a guess as the old one was quite old, flattened and deteriorated. It also may have been what someone else sourced to replace the original.
Let me know if you want the o-rings- I will drop them in the fast- mail !
greg moore
Leverwright
LMWDP #067
mogogear
Link to "The Arrarex Caravel"by peacecup on Thu Jan 10, 2008 3:16 am
Here are a couple of mogo's original photos of the piston assembly - more can be found on this thread:
Each of the three assemblies on that thread appear to have slightly different designs.
The little O-ring in the center of the piston is the one that is damaged on my machine. I'll ask Greg to mail one up, then try to match it locally for some spares.
The O-ring seals the piston in there:
The temporary fix is working well for now - today's espressos were all pretty good. I'm getting the hang of it. The basket is surprisingly large- it holds up to 10g.
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by peacecup on Mon Jan 14, 2008 11:27 pm
Towards the end of last week the shots I was pulling on the Caravel seemed to be varying considerably in quality, something I haven't experienced in a long time. I was experimenting with different doses, grinds, tamps, and beans, and some shots veered dangerously close to sink shots. I think the ability of the Ponte Vecchio to handle anything I throw at it terms of grind/dose/tamp had made me a bit complacent, and I'd forgotten the Golden Rule of varying one parameter at a time. Over a three-day weekend away from the Caravel my mind kept coming back to the last few shots I'd pulled - they were thin and watery. I'd loosened up the grind and increased the dose - the flow rate seemed good, but the shots were poor, blond, thin crema.
Today I settled on a consistent dose, stuck with one blend, and adjusted the grind until I got really dialed in. I was rewarded is some great 7-8g ristrettos. I plan to keep things very consistent for the next couple of days now, to work on getting this type of shot further dialed in before switching to other beans or increasing the dose.
I'm also sticking with one temperature for now, which is a gently rolling boil in the kettle, then switching off just before brewing.
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by peacecup on Mon Jan 14, 2008 11:33 pm
Oh Henry, BTW, the in the photo of your Caravel from the youtube video the lever appears to be installed upside down (the "elbow" pointing up). I installed mine in this direction when I first got it, as in the photo at the start of the thread. I've since switched it, which allows me to engage/remove the PF with the lever in the full down position and the piston closed.
All this reminds me to mention that the two-armed lever with the horizontal, rotating handle on the Caravel is really a far superior design to the one-armed bandit common to most levers. With a spring lever this hardly matters, but with a manual lever it makes allows a far smoother, more consistent pull. Just another kudos to the Caravel designers...
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by hbuchtel on Tue Jan 15, 2008 1:12 am
peacecup wrote:Oh Henry, BTW, the in the photo of your Caravel from the youtube video the lever appears to be installed upside down
Heh heh :) yep! Dunno why I thought it should be facing down. Using it the other way, it is obvious that it should be facing up!
I have to re-train my muscle memory, however, as I no longer know when to expect the normal build up and let down of pressure...
Say, have you tried an americano? It is really easy with the Caravel- just make sure you have plenty of water in the kettle and fill up the cup before pulling a shot (I'm using a small cappuccino cup). I've never really been into americanos (americani?) before, it is really interesting how the flavor of a straight espresso is all there, but different... much less intense, more diffused... (which makes sense :roll: ). I'm excited to try some lighter roasts as americanos as I've found them too objectionable as straight espresso.
Henry
LMWDP #53
hbuchtel
Link to "The Arrarex Caravel"by missionhb on Wed Jan 16, 2008 12:12 pm
Hi All,
Just a personal note on the Arrarex VAM/Caravel. I noticed that the early models - those with a side Sphinx and VAM tag and no "Caravel" front sticker - have a few distinctive features:
- the lever is more bended/curved and less tubular in section (the shape of the section is changing gradually)
- the heating element is 600 W
- the upper back knob releases the water tank
- the lower back knob regulates the thermostat
- there's no on/off switch
- the lid of the watertank is released an "pops up" by operating a tiny lever
- the water tank presents two series of holes towards the compression chamber for water entry/air escape
- the piston assembly is released by unscrewing the upper locker that operates subtle retractile threads
- the central lever fittings are carved into two inox hemispheres
- there are no O-rings in the chamber or on the piston
- the piston is plain inox with two V seals mounted in opposite direction (like pavoni's)
With this early machine, if you take care getting rid of any residual air in the compression chamber by two or three slow and gentle halfway preinfusion strokes (until the lever is stiff), you can litterally "lie on the lever" and extract amazing ristrettos & espressos from 8-10g finely ground and strongly tamped pucks, without any hydraulic back-leaks.
The result is amazing.
Cheers
LMWDP CLXXIV
missionhb
Link to "The Arrarex Caravel"by hbuchtel on Wed Jan 16, 2008 10:40 pm
Hello missionhb (?), thanks for joining us!
From your description, I think you have the same generation of machine that Walter does (see photos here). Mine (and Timo's) seem to be the newest generation, while PC's is somewhere in the middle. As far as I can tell, the changes from generation to generation were made to save money rather then improve on the original design!
I've tried doing a pre-infusion pull like you mentioned, but never got very good results... but with your endorsement I ought to try it again. About how long does the pull take for you and what is the weight of the drink that it makes?
Regards,
Henry
LMWDP #53
hbuchtel
Link to "The Arrarex Caravel"by mogogear on Wed Jan 16, 2008 11:30 pm
Jack-
O-rings and Dow 111 in the mail yesterday!
greg moore
Leverwright
LMWDP #067
mogogear
Link to "The Arrarex Caravel"by missionhb on Thu Jan 17, 2008 6:25 am
Hi Henry,
In the conditions I described earlier: (i) all the air is purged from the compression column i.e., cylinder PLUS free space in the PF between the puck and the dispersion screen, and (ii) heavily tamped 7-10g puck, the pull takes 25-30 seconds and yields an unbelievable 13-18g ristretto/espresso.
Best,
François
LMWDP CLXXIV
missionhb
Link to "The Arrarex Caravel"by peacecup on Fri Jan 18, 2008 4:41 pm
Greg, many thanks, they arrived today, fit perfectly, and I'm currently awaiting the machine to come up to temp for the first try.
I'm getting the Caravel dialed in, and am really loving the shots, not to mention the beauty of the machine.
PC
LMWDP #049
peacecup
Link to "The Arrarex Caravel"by ntwkgestapo on Fri Jan 18, 2008 5:46 pm
Peacup, don't know how easy it'd be up there in Juneau, but. the absolute BEST place I've ever found for round seals (i.e. o-rings and variants) is your local boat engine repair shop. Unbelievable selection of o-rings, flared seals, etc. in just about ANY size (from itsy-bitsy [don't you love the technical stuff! :D] to 6-8 inches in diameter). You'd be surprised just how many different seals go into outboard motors, jet drives, etc and OFTEN they can be found in food safe form....
Steve C.
I'm having an out of coffee experience!
LMWDP # 164
ntwkgestapo
Link to "The Arrarex Caravel"by alex f on Sun Jan 20, 2008 6:23 am
Hello fellow Caravel owners.
I have been using one of the older models for a few weeks and have a question about one of the parts I seem to be missing. It's the steel sleeve that encases the lever mechanism inside the piston chamber. Does it strenghten the unit ? Does it simply prevent water from leaking out of the chamber when the kettle is too full ?
Alex
alex f
Next
