by peacecup on Thu Jul 10, 2008 6:52 am
Well, back at it this thread after a little break. The shots from my Caravel hit their new peak today. Started off normal enough with an AM cappa, which was just normally good. I've got the open-boiler routine worked out well now. I get the Caravel ready, then turn on the electric range and get the coil hot for milk. When I lock in the PF I do a ~10 sec preinfusion, and then set the milk on the stove while I pull. When the shot it done the milk is hot, and a quick froth with an Ikea hand frother makes very acceptable foam. With access to a nearby stove the lack of a pressurized steamer is not much of a hardship.
The PM shots were straight, and they were really good. I'm still using Italian beans of unknown roast date, there are Molinari fair trade espresso. I pull a different Dienes off the shelf (finally unpacked them), and tried an experiment. This Dienes is the first one I bought, and I've been using it now since around 2002-3. I tightened the burrs just about as far as they would go and ground. The grind was quite fine and resulted in a slow pull with the Caravel, really an almost constant drip. The shot was very tasty with good thick crema - espresso syrup. It was so good that I had to pull another right away (and the beer I had for breakfast wasn't bad.....). This time I backed off on the grind about ¼ turn, so the burrs were just comfortably meshing. I compensated by tamping a bit harder, and the second shot was even better. Superb mouthfeel, and the range of flavors coming though, with a little tangy bite at the end. And minutes later as I write this the taste is still lingering, calling me back to the Caravel....
The Caravel is really an underrated manual lever, perhaps because it is so rare, or because of the open boiler (no steam). Really I think it's the small portafilter though, that many home baristas consider a toy when they first see. I think the reaction to the 45-mm Ponte Vecchio is the same. It's a shame, really, because these micro machines are very capable of brewing, and maybe even distilling, the true essence of espresso.
LMWDP #049
