by orphanespresso on Thu Mar 20, 2008 4:43 pm
This is what Dow has to say about the 111:
MIDLAND, Mich. - April 19, 2005 - Dow Corning® 111 Valve Lubricant and Sealant is a heavy-consistency dimethyl silicone compound that resists a variety of organic and inorganic chemicals.
Dow Corning 111 Valve Lubricant and Sealant can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft vacuum systems, electronic and ignition systems, among others. It can be used as a sealant in applications such as vacuum and pressure systems, equipment subject to washing and harsh environments, electrical service entrances and underground connections, and transformer gaskets and equipment enclosures.
Dow Corning 111 Valve Lubricant and Sealant maintains a serviceable consistency from approximately -70° to 400°F (-57° to 204°C) and has NSF 51, NSF 61 approval and is acceptable as a release agent under FDA 21 CFR 175.300, when used in accordance with that regulation.
