Javier wrote:Could you please post side-by-side pictures of the single and double baskets (or at least the dimensions)?
As soon as I get the Caravel double basket I will post a side by side, unless someone gets there before me.
Javier wrote:I am getting the same results in the cup - "drippy" espresso, and less crema and no tiger flecks (when compared to my Gaggia Factory). But the taste is so amazing. My wife refers to the shots as "clean" and "not bitter" (for lack of better, or more descriptive, terms).
Thanks for bringing to our attention your experience with shots pulled around 70 C. Is that with the thermostat (termostato) dial turned all the way to the right (clockwise)? I will like to experiment with this tomorrow morning.
Your description of "clean" is a good one. Definitely cleaner, less "muddy" if that makes sense.
The thermostat isnt quite turned all the way to the right, but not that far off. The thermostat is so wonderfully rudimentary. It will get to your desired temp consistently without fail, I suspect, for many years (as I guess it has for decades up til now). It is pretty clunky of course - a couple of clicks will shoot the temperature deadband off by some margin, and the cycling deadband itself is not exactly, ah, tight! But that is part of its charm, and as long it can cycle off when it reaches the initial temp then that is perfect. The fact that it works at all given its age is almost miraculous.
hperry wrote:While I have and use single baskets for the VAM, Caravel and Peppina I don't find them inherently superior to the double basket. Either allow a well controlled ristretto shot.
I think that is correct, at least as per my new found experience with the PVL. This is personally significant for 2 reasons: 1) single baskets are no longer objects that I look down upon with suspicion and pity, achieving nothing except clogging up my accessories tray and 2) the double basket will indeed match the single basket - as long as I downdose and grind finer. I am expecting my experience with the Caravel double will be the same. But who knows.
hperry wrote:I don't think these gems were designed for the brute force some recommend using
A firm, solid stroke yes, but I think if you are at the point of rupturing a bowel with effort then I think you are pushing these fellas a little too far. They aren't pump machines. I cant imagine the Italians of previous generations would have used it this way (not would they have wanted to), and therefore not designed in this way. But each to their own, and if I prefer lower temps, then others are completely justified in forceful pulls if it works for them.
And once again this morning, the espresso from the Caravel single was markedly cleaner and clearer than the PVL2 - either single or double. More coffees to try out - blends and SO - though before I think I can conclude absolutely.
