samgiles wrote:Hi everyone at team Caravel.
1. My basket appears to be punched so that it's permanently lodged in the PF. I can't move it at all. Is this normal or can others be taken out.
3. Is there a trick to getting the PF gasket out? It's wedged in there pretty tight and I'm afraid to damage it.
Hope someone can help.
Sam.
It is not welded- nor is it punched in. It is just very tight fitting. You will see that the edge of the basket overlaps the PF edge by a fraction. Use this 'ledge' to begin prying the basket away from the PF- don't worry about breaking it. You can pry against the PF locking flange thing to begin. Use something strong and flat and very thin.
Once you manage to move the basket a fraction use your strong flat thin thing to wedge in here and there working the basket out. It will come out. It's probably a bit jammed with coffee scum on the inner edges. I find once you have it out a bit the end of a teaspoon makes a good lever against the flange and 'ledge'.
I assume you were thinking the little dimples are where it was punched in- these are just to make it snap in- I have found on many machines it to be very tight and seem jammed or permanently fixed when first inspected. Then I get out my thin, strong flat thing...
