samgiles wrote:
1. My basket appears to be punched so that it's permanently lodged in the PF. I can't move it at all. Is this normal or can others be taken out.
2. Underneath my drip grate there is just the orange body. I guess I'm missing a drip tray?
3. Is there a trick to getting the PF gasket out? It's wedged in there pretty tight and I'm afraid to damage it.
samgiles wrote:1. My basket appears to be punched so that it's permanently lodged in the PF. I can't move it at all. Is this normal or can others be taken out.
Sam.
mogogear wrote:That darned little o-ring... I see that small devil still is a problem in design...it needs a cylinder shaped or barrel shaped seal that sits in a deeper recess...
Cheers jack
peacecup wrote:Yes, it was a little too slow, I didn't have it exactly dialed in for the new blend. But, only a little too slow, I really like a very slow stream, imagine slowly squeezing the water through the puck.
Full basket, and I usually use the following:
1. Lift lever to fill
2. Knead the lever down to preinfuse, just till one drop falls
3. lift, and repeat,
4. lift, and begin extraction
5. when the lever is about at 3 oclock I judge from the color and speed whether I should relift and do another pull (if very slow) or just finish it off.
The shots are just so great these days, and very consistent between good and better!
PC
