peacecup wrote:to calrify,
I'm only doing repeated lifts of the lever during a "Fellini" pre-infusion. i don't use a second pull on the Caravel, although I tried it once and it wasn't as bad as I thought. I may experiment with it again.
Hal, I've never had any success with any machine and a no-tamp. I should probably give it another try, but I always seem to end up with faster blonding that way. With the Caravel, I was getting early blonding (before the lever got to the bottom) as long as I did not really fill the basket. With the basket totally full, I can take two pre-infusion pulls (very few or no drips during these), and the third pull all the way to the bottom with no blonding.
I don't quite get "red", but I'm putting on as much force as is comfortable.
I should probably note here that I'm using commercially-roasted beans from Italy, roast date unknown. The Italians much be great blenders and roasters, because even with old beans I still get good espresso.
Even when I have fresh beans, however, I still seem to get the best results with the full basket.
PC
Matteo wrote:"Hi Henry,
My grandfather's name is Atos Beltrami: he was the entrepreneur who started VAM and Arrarex and a true coffee lover. He designed the features of the machine with Dr. Salati, and his brother . My grandmother still recalls the endless trials and discussion that were made in the apartment in Milan where I grew up. (although I believe the firm was incorporated in Correggio, near Reggio Emila, which is my grandfather's native city)
I'm going to see my grandma on Christmas, is there anything that you would like to know?"
hbuchtel wrote:Hello fellow Caravelites,
I got this message from Matteogd on youtube-
Cool, huh?![]()
Any questions for Matteo?
peacecup wrote:Top of the list, though, is why the very small PF basket diameter (i.e. narrower and deeper than a 58mm)
One would assume that Sr. (Ing.?) Beltrami was working with the same constraints
IMAWriter wrote:Having owned both a 51mm Pavoni Millennium and my present Oly Cremina, I can CATEGORICALLY say they are NOT similar in more respects then you might think.
Boy, every time I read this thread, I get the urge to have a Caravel on my counter top.
orphanespresso wrote:... part of our curiosity is the small size of the pf as you mention and if there was a deliberate design to the physics of the machine or was it simply scaled to fit the counter. .
