peacecup wrote:Alex, if you can find a photo from one of the earlier threads and post it here that might help. I'm not sure which part you mean.
peacecup wrote:My Caravel shots on Friday were quite good. A new O-ring for the piston center hole, and some Dow 111 from Greg seems to have helped to increase brew pressure a little.
In my experience so far I find that the shots blond towards the end of the pull no matter how I grind/dose/tamp. The flow usually slows to a fast drip and begins to blond towards the end. Anyone had any experience with this, and found a solution?
Also, what temperature are you Caravel users pulling shots at? Full rolling boil, pre-boil, post boil? I have yet to even put a thermometer it the boiler or brew water, but plan to do so soon.
I've found that the Caravel PF is just 1-2 mm smaller diameter than that of the Ponte Vecchio. In fact, the OD of the baskets are the same, the ID diameters are what varies. This got me thinking that a new Ponte Vecchio group head gasket might fit the Caravel, and I'm anxious to try this. DUring very hard pulls on the Caravel I get a few drops of water escaping over the PF, which suggests a new gasket is in order.
PC
peacecup wrote:... if I grind coarse enough for just a "firm" pull I don't seem to get enough pressure to produce much crema .... if I grind finer and try "no tamp"... the pull ... becomes too firm at the end. I need to kepp working on these things.
alex f wrote:I'm missing the metal cover at the top of the pic. The machine works fine, but knowing that the part exists, I'm a bit wary of pulling too hard on the lever.
