Arrarex Caravel - Eater of Seals
- GVDub
- dumpshot
Holy crap! That is weird. I have never seen anything like that. I am trying to visualize what could make those symmetrical grooves. Do you know what orientation the seal had inside the group? Is that the top or bottom seal? It is catching on something. Does the piston action reflect this? I mean, can you feel any hiccups in the piston movement? Can you feel up inside the group cylinder and feel any burrs?
I am sure you have thought about all these things, but I just can't wrap my head around how this could happen. They are like espresso crop circles to me.
Pete
Pete
LMWDP #484
- GVDub (original poster)
Bottom seal, and though I haven't measured to any degree of precision, it looks to be about the distance between the outside holes of the water inlet. Did not feel any "hiccups" or catching in the lever movement. lAlso found what would appear to be one of the "slugs" inside the boiler. Some sort of burr on the edge of those holes? I hesitate to take an abrasive to the interior of the cylinder.
"Experience is a comb nature gives us after we are bald."
Chinese Proverb
LMWDP#238
Chinese Proverb
LMWDP#238
- crazy4espresso
The lower seal can catch on the openings in the group where the lever attaches, but this only happens when the piston is installed. You sure this didn't happen immediately and not over time?
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
That would put the "bites" 180° from each other, and these match up pretty well with the two end water inlet holes. Definitely happened over time, though, not immediately, as there was a sudden loss of pressure while pulling a shot.
Chinese Proverb
LMWDP#238
Chinese Proverb
LMWDP#238
I need to source some seals in number so I can do some testing. Now that Doug and Barb are only selling master kits with mostly seals that I won't need, it's a little pricey to get, say, 6 or 8 of the u-cups.
Chinese Proverb
LMWDP#238
Chinese Proverb
LMWDP#238
- dumpshot
The white U cup seals that Kurt August sells in the buy/sell forum are really robust and fit just right. You may want to contact him about gettin some.
Pete
Pete
LMWDP #484
- SimonPatrice
So, I'm not the only one having trouble with my Caravel seals. I manage to break the tiny o-ring on the bottom of the piston every couple of months (probably from too fine a grind, I guess). But, part of the upper seal of the piston gets "shaved" by the groove on top of the sleeve when I put the piston back in place. It's as if the seal was a little too thick.
For reference, my piston is the second one from the left:
(picture from sorretinacoffee)
So if you find a cheap source for individual seals (or the tiny o-ring) let me know.
Did you find out if yours was damaged by the water inlet holes?
Patrice
LMWDP #428
LMWDP #428
- Italyhound
grainger.com sells o rings. The tiny o ring is 4 mm and they do sell them.
- SimonPatrice
They seem to be safe for use with water but would they be suitable for use with boiling water?
Patrice
LMWDP #428
LMWDP #428
