caeffe wrote:Robert-
You've described what sounds like the "Fellini" pull. Basically, a half pull (sometimes 2-3x) followed by a full pull. Do a search on Fellini here.
For me, on my europiccola, I've given up on the fellini. I find that i get an overextracted, hence bitter, pull.
I've stuck with one single continuous pull. I get better, sweeter results. So what if i don't get the quantity. I get quality. Also, I try not to "force". I've found that forcing it causes the shot to freeze as you described. Relax, let up on it, heck even stop. Magically, you'll be able to finish the pull. I think this is the difference with a fully manual lever. You can feel the pull.
Mind you, again, I don't have a Cremina, just a lowly 'picolla. But I think the two machines are so alike. This behaviour was described in another post somewhere here. Not sure what you search under.
peacecup wrote:From your description of the symptoms you've got "manualleveritus". Either your machine is malfunctioning, or you're trying to stuff a two pound salami in a one-pound skin. If the former, you can send the machine to Peacecup's Cremina Repair, Karlstad Sweden. We'll get it back to you as soon as possible. Please pack it well so we can do some thorough testing.
If the later, Dr. Peacecup prescribes taking a deep breath before you begin your espresso experience. Perhaps a minute of meditation with a hand grinder. Espresso is not a competition sport, but a journey, not only of sight and sound but of mind. Put away the stop watch, and loosen the grind a notch baby, and try not to break the lever on that Swiss beauty. For God's sake Jim, I'm a simple county doctor, but I can tell you've got the grind too fine.
As you can tell by the above prose my Caravel has finally arrive, and I am back in lever heaven. Anyway, good luck getting things sorted out!
PC
