Ray- I have thought about that- however having a probe mounted to the pf- or basket- would be very inelegant. The good thing about the neck of the group is that is the point where the thermosyphon connection warms the group- and there is already a hole for the probe in the perfect spot. It will be nice and clean_ the probe wire will emerge from the face of the machine just under the group and bolt in at the underside of the group... all things going to plan.
The probe would not read the temperature at the coffee- but I think it would be close when the machine is at full operating temp- likely a few degrees lower? I thought it may be possible to extrapolate the difference (possibly by doing some tests with another probe in the puck) and to then calibrate the group probe accordingly. It may be that the temp is all over the place- and won't tell me much of use- but it will still be fun to watch! As soon as water is drawn into the group the neck heats up rapidly. After a shot the temp declines and stabilises. Being able to accurately read the temp at the group when the machine is turned on but not being used- and being able to control the boiler pressure easily- may allow me to determine to optimum setting for the boiler pressure in relation to the operating temperature of the group head vis a vis the thermosyphon loop
Even better would be to drill a hole right into the back of the piston- with the tip just inside the cylinder. This would show the changing temp throughout the shot as the group draws heat from the water. I imagine the tip would have to be perfectly flush with the piston wall though (it may work if it was inset a little- but would probably cause leaks as the piston seals pass over the hole)- and I would never attempt such a difficult mod.
Unlike you: I don't see myself lowering the pressure of my boiler much- the difference between the Pavoni and the Sama is the heatsink abilities of the group. Even though the water in the boiler is near boiling- the group can consistently draw out and dissipate the excess heat before the water reaches the coffee. The Pavoni at normal operating pressure can only achieve this feat once- before the group overheats. You need to let the entire machine cool before you can go again.
I have never quite understood how the Sama and the PV thermosyphon group attachments do their trick: I understand how the thermosyphon operates to pre-warm the groups- the boiler water can circulate in the neck- but I am not so sure how (or if) the loop draws heat from the group after a shot. I would have guessed even after a shot the group would still be cooler than in the boiler... But it seems that it does? I am not sure if this is due to the loop- and/or the group designs (large amount of brass- bolted to a frame which is removed from the boiler= rapid heat sink and dissipation= group cool for second shot)...
Jim,
you set up looks perfect- much smaller than a standard boxed PID- thanks for posting those quality photos. It looks like I could mount most of it in the base under the boiler (which should be a cool and dry spot for the electronics)- with only the display mounted in the main cabinet beside the boiler...
With you LCD (?) display- does it have a faceplate- or would you drill separate holes for the four buttons? Would it be possible with your set up to use a different type of display? Like LED? I already have a hole in the face where the on/off rocker switch was- that hole is 35mm high by 20mm wide- I can safely enlarge it to 60mm in either direction.- it would be incredible if I could somehow squeeze two micro LED temp displays into the existing hole- stacked on top of each other- boiler in green and group in red...
