Used Samas and PVs are not easy to come by, so I looked into a new purchase. It seems there are currently 2 dealers in North America that carry this unit. As prof_stack had nice things to say about A Good Coffee Company in Seattle, I tried them first. Joe at GCC is a very nice guy, but he is not really set up for cross-border, long-distance sales, and the hassle (combined with a possible excess of questions from yours truly) soured his interest in shipping me a machine! Gensaco was my second choice, since they did not seem to have the same level of machine knowledge or interest, but they sell the Export a little cheaper, and...they would sell me one.
So here it is, sitting prettily next to my Brewtus II, just to give a sense of proportion to an E61-style machine:
Everything about the machine is new to me, and the tamper that comes with the machine does not fit into the filter baskets, so until my Reg Barber 45mm piston shows up, I will refrain from posting any shots:
The elegant simplicity of this machine appeals to me. The stamped steel pieces covering the top of the machine and the drip tray are interchangeable:
The qualities that make the machine appealing to me carry through to the inside. I noticed that the boiler cap has a little hole drilled into the threads in case an over-eager user attempts to unscrew the cap while the boiler is still under pressure:
I also liked the way the water level appears as the colour of the casing in the sight-glass:
The Export takes about 10 minutes to get to heat. I have so far only tried the double basket using 12 grams of coffee, and the single basket using between 5 and 7 grams. The other reason I wanted the Export was that the low water draw lever machines are built for low volume shots that use low volumes of coffee. I really like the idea of making smaller coffees, more often. Also, the coffee market seems to be going in a direction where the home-barista can snag some expensive, ultra-premium coffees. A 5-6 gram single or 10-12gram double yields a lot more shots from a small roast batch than what I would be brewing up in a 58mm PF.
I'm really looking forward to getting down to some brewing. While I've read pretty much every post in the lever forum, I would certainly appreciate any advice for a first-time lever head.
Mark
