Hi Folks,
I'm posting this as its own topic so it will be more visible and invite discussion.
I just bought a used Microcimbali and caught a post that another member here got a similar machine. But he was less fortunate than me and discovered his aluminum boiler had corroded to the point it can't be fixed. A discussion started on that thread about how to maintain and clean aluminum boilers. See:
Newly acquired Microcimbali Liberty: had a few restore questions Here's a summary of the aluminum boiler issues discussed there:
1. Aluminum boilers can corrode and die
2. Doug Garrott (orphanespresso) advises to chrome plate aluminum boilers if you want one to last long
3. Another poster says both aluminum and chrome can oxidize, so this may not be a solution
4. If you empty an aluminum boiler, does it still oxidize in humid air?
5. If your aluminum has oxidized, do you want to descale? Or, would descaling remove the oxidation that can serve as a protector against further oxidation. In that case, would you remove extra scale with a wire brush?
I followed the instructions on the Microcimbali base and emptied the water in my other aluminum boiler machine. I recall aluminum window frames that corroded on the outside, not the inside, and I guess this is because only the outside was exposed to rain.
I'll add another consideration.
6. Does consuming water heated in aluminum create an increased risk of dementia? The topic is controversial because I've seen online articles that the plaques in Alzheimer's patients can form around aluminum oxide and other, later articles that say no sufficient link has been made between using aluminum in cooking and developing Alzheimer's Dementia -- I'm not a physician or researcher, so this is only a consumer-level reference. (I don't know that cooking in aluminum needs extensive discussion considering how little water one may consume from an aluminum espresso machine.)
Your thoughts?
