samgiles wrote:It bothers me because I can't push the handle round more than a couple of mm. .....
Yikes, now I understand. that would be bother me also.
mogogear wrote:The MCal baskets are too deep for some PF and some not--- It is unfortunate but you might just revert to the obvious and buy some LP baskets...
Mine apparently is too deep. I tried lessening the od of the flange as you noted before, albeit using a different method which may have exacerbated the basket not fitting under the grouphead. I reverted to the obvious and bought a LaPav basket from partsguru.com along with a full gasket/refurb kit from them. Unfortunately I haven't had time to use the new basket and compare against the MCAL basket.
