timo888 wrote:When a 1970s era brass boiler has lost its plating, should it be replated before it's used on a daily basis?
Regards
Timo
espressme wrote:When I spoke to the folks at a major espresso parts supplier, They suggested a replate rather than using. However, look at all the rebuilds!
espressme wrote:They all have a very small proportion of lead and have been in use and still are in use for boilers.
espressme wrote:I believe the factor you are interested in is the "leaching" of metals by hot water over a period of time.
timo888 wrote:Correct. If it's not too expensiveto replate with food-safe nickel, I think it would be prudent to have it done--based on info I have found since posting the question. Lots of info on brass cookware.
Regards
Timo
Paul wrote:Not all makers adopted plating. Faema and gaggia have used plating since the mid '50s whereas the likes of smaller makers, eg carimali, never bothered. I am sure that it was done early on as an aesthetic thing rather than anything to do with food safety.
Of all the dangerous things in life I face, lead poisoning from making coffee using machines with exposed brass and copper is, I think, a pretty low risk. Now, whether the worn Ni surface is a risk may be another matter. I polish this off during restos.
Each to their own, I don't mean any of the above to be advice.
mogogear wrote:There is a lot of copper pipe in lots of houses in many places, also brass elbows and fittings that are in line with hot water heaters etc......... I am going to keep my worry meter down - same as Paul- not to be taken as advice- everybody is in charge of their boat- I just steer mine.
