This is the second time I've descaled my Sama Lusso in a month (Club?), I use only the best brand spring water I could find around. I'm trying to reduce the pressure a bit to the spot everyone suggested here (1,1bar?), curious how it taste!. No matter what I do, descaling or set the p-stat at the lowest setting, still its needle stop at little over 1,5. This picture I took about a month ago or so, now it's even gone higher a bit maybe 1,6 or 7.
Would you suggest to change the p-stat? or is it something to do with the gauge? And btw, the p-stat is SOPAC type "PS", and it has one free lug numbered "2". If look at the switching schematic on it, the wire is connected to 1. When I got it, the cable was not connected to either lug (1 or 2) so it must be disconnected during a long way shipping from Holland. I was just guessing and get it connected to 1 and the machine heated up. Could this be the issue? I have not tried to connected to 2 tho.
Thank you for the advice.
BTW, If even you would suggest to let alone the machine, I would too, as I still enjoy my everyday espresso, it just to fill the curiosity.
