Followup:
I got my first single-pull 1oz shot tonight. I found a grind that nearly choked the EPC, backed it off a notch, and with the help of the boiler being on high heat, I got consistent resistance the whole way down which resulted in a slow pour. I've tasted better, but at least now i know the very basic goals I was shooting for are possible.
I have a question about daily maintenance; I was pretty happy with the maintenance schedule for my silvia: grouphead brushing, portafilter wiggle, and backflush after every morning session, leaving the machine clean and ready for the next use.
My EPC, however, seems more problematic. I've tried holding a glass of water up to the grouphead and sucking in water then expelling it repeatedly.. it'll dislodge some grounds into the glass, but leaves many grounds up near the gasket (past the dispersion screen where all the water movement is when I pump the lever). The only way I've managed to remove most of them is to use a q-tip, but I don't like the idea of wasting disposable qtips so often. I tried getting in there with my pallo coffeetool but it doesn't really fit up there, and besides, I'm not sure what else I might be missing.
What do you EPC owners do to keep everything spotless and ready for tomorrow's session?
