hipponax wrote: ( . . .) but my machine seems to go too far: the shots are just not quite hot enough; close, but not quite there. ( . . . )
hbuchtel wrote:No advice, just questions
Usually if you pull a succession of shots on a Pavoni each one will be a little bit hotter, is this not happening for you?
Does your model have a pressure gauge?
Henry
kbuzbee wrote:Hi Ralph, you didn't mention whether you're bleeding off pressure (through the wand) before pulling a shot.... Sometimes a false pressure will cause the pressurestat to cut off too low.
Just a thought.
Ken
bobby yarrow wrote:I'm kind of a numbskull, and it took me a while to realize that there was no difference between pressure and temp with my europiccola; all the pressure is obtained from the heat of the water, yeah?
