entropyembrace wrote:I've been trying to dial in Farmers Collective from Social on my La Pavoni Europiccola...where I am now I'm dosing 14g solid and getting a 28g shot with a 5 second pre-infusion and one lever pull. It tastes ok...but its a bit harsh and I know from brewing it as french press that this coffee has the potential to be a lot sweeter...
Anyway it's been suggested to me that a bit lower of a brew ratio is better with this coffee...1.55 or that I should be getting 22g from my 14g dose...but I'm not sure what is the best way to go about getting this ratio?
Should I just pull the cup when my shot reaches 22g?
Should I try grinding finer to reduce the flow?
Should I grind finer and dose lower like Jim's adjusting by taste guide suggests I should do to increase sweetness and just go with whatever brew ratio that gives me?
Is there something else you lever heads would suggest?
14 grams is what you would normally use for a double shot (i.e. 60 grams of espresso in the cup). If you are only pulling 29 grams (i.e. a single shot), then your dose amount should be more around 7 grams of coffee. Anything over 7 grams would be considered an up-dose.
On my La Pavoni, I use 9 grams of coffee and pull 30 grams of espresso. That's a very good ratio in my experience. I generally use a slight pre-infusion (maybe 3 to 5 seconds) and then aim for a pull of about 30 to maybe 35 seconds or so. Myself, I usually like the pull to be a little on the longer side, although shorter pulls (down in the 25 second range) are good too sometimes.
I use the Elektra single shot basket from Stefano's on my machine. It works really well (since it's necked down at the bottom) and allows you to tamp between 8.5 and 9.5 grams of coffee. As mentioned, I usually dose 9.0 grams and pull 30 grams of espresso. That seems to be the best ratio I have found recently if you want smooth tasting espresso.
Before switching to the single shot basket, I was using 12.5 grams for a single shot (30 grams of espresso), but I found the flavors were more on the harsh side and too concentrated. Even with cutting out the first part of the shot, I wasn't having much luck.
Naturally, a lot depends on how you like your espresso to taste. If you like Ristrettos, then maybe 14 grams for a single shot might work okay. Myself, I find 8 or 9 grams works nicely for a single shot, especially if you are getting a thorough extraction across the entire puck.
Ray
