Ray,
Did you try the "active pre-infusion trick" to increase the shot volume? Pull the lever up all the way, wait for 1 count, pull the lever down slowly until you feel a slight resistance, pull it up again,and then pull it down...repeat this for about 1-5 times. Some says it disrupt the puck etc etc, but with my bottomless, I don't see any channeling so I would use it when pulling a double shot for latte.
This way, you could pull a bigger volume than you need and just pull the cup away when it reaches your desired shot weight. Since you like a more traditional shot, try aiming for 50% brew ratio. For example, 15g coffee to 30g shot (not ml, they are very different). This technique allows you to build a stronger cappa if that's what needed.
entropyembrace wrote:I do have a temperature strip on the brewhead....I've been pulling around 200-203°F
Tera,
Try pull the shot even before the temp strip has color on them (Just before 195F, with the grouphead too hot to touch). Depending on set pressure, 200F on the temp strip can be too hot and might result in higher than 200F brew temp.
