Finally I've got the additional spring to Mini Gaggia. I've done some calculation and talked to the spring shop, so the final product is 96mm long, has 27mm external diameter, 20mm internal diameter, 3.5mm wire, 11.5 total coils made of AISI 302 SS:
And installed:
They tested it and the spring rate is 1,125 kgf/mm. So it should add around 2 bar (38 kgf) when the piston seal the chamber (considering 18.8 mm² of area), as the spring installed has 82mm and when sealing the chamber has around 62mm. Most important is the coffee - I've done some tests with the Gaggia Achille filter basket and using the same 18g and finely ground coffee the spring did a similar job on Mini Gaggia that my arms on Achille (I hardly can reach 8 bar, measured with a gauge on the porta-filter).
The lever is heavier now, for sure, but a normal size man or woman can pull it. I'm using the porta-filter to counter balance. Maybe a 8-10cm addition to the lever could help a little bit, but with less balance - perhaps it would require the other hand to hold the machine base or back.
The machine support and screws don't seem to care about the extra force.
Note to anyone that would remove the piston (unscrew it): hold the spring at the current length with cable-ties (a lot). I've used 3.5mm wide cable-ties, maybe 4-5 around each coil, to hold the spring at a enough length so I could screw the piston back to the shaft.
I have 12 more springs, I think 6 or 7 of them are going to Europe to a fellow HB member that could send the spring to other Mini Gaggia owners. If anybody is willing to take 5-6 at North America, I could send them. The cost of each spring is 7.5 USD.
Márcio.
