Here are photos of the procedure. First, the thermometer and the rotary tool with a cutting wheel used to cut the plastic around the steel sheath for removal. Be sure to use protective eyewear when using a cutting wheel as these can fragment and fly off. At the top are two high temperature silicone rubber pads I cut to shield the thermometer from the heat of the machine.
The pads were cut using a leather punch on the gasket material:
The leather punch was an inexpensive eBay set that came in metric sizes:
I used Blue Tack to stick the thermometer and the tip of the probe wires to the machine.
First I rolled and applied a bead of tack to the sightglass bracket:
Then I applied a silicone pad as a heat insulator:
Next I applied tack on top. To securely hold the thermometer I added a second set of these:
I used some more tack to make sure the wire leads are not touching the Pavoni boiler. Here tack is attaching the end of the probe wires to the back of the group:
Here's how the machine looks with the thermometer installed:
I will dial in shots using taste as a guide and correlate that with the group temperature readings. These will not be the actual temperature inside the group but should correlate very closely. AndyPanda used partial pumps to heat the group, and I'll follow that procedure. Without thermometry one otherwise monitors temperature with the manometer I installed on top of the sightglass. This is a machine that is manually operated with Low and High switches to get to temperature. It pulls great shots and is a powerful steamer once you learn how to "drive" it.
