Adding Pressure Gauge to Olympia Cremina
A haven dedicated to lever espresso machine aficionados.
Link to "Adding Pressure Gauge to Olympia Cremina"by AlexH on Wed Feb 03, 2010 5:55 pm
I want to make either a steam wand or Boiler cap attached pressure gauge for my cremina 67.
What type of gauge should I look for? Are some clearly wrong and will not work?
Looking at these two cheapies on ebay
http://cgi.ebay.com/Ametek-Utility-Pres...4837c0ace8
http://cgi.ebay.com/New-Wika-Pressure-G...2913wt_943
The second looks like better quality, but not such a tight pressure range. I am comfortable with having to convert from bar to psi.
Thanks
AlexH
Link to "Adding Pressure Gauge to Olympia Cremina"by robert mayrand on Wed Feb 03, 2010 9:35 pm
I just did this with the old cremina cap I had. I used omega gauge, check this link starting at 11$ it's really a good deal.
http://www.omega.com/ppt/pptsc.asp?ref=PGU_Series&ttID=PGU_Series&Nav=
You can choose your connection back or lower connection and the size. I took the 2.5" with back connection so I read the dial from the top. 1-2 bar Is the more appropriate it's quite useful to get the info in bar instead of just PSI as seen in the ebay auction.
Rob
LMWDP #274
robert mayrand
Link to "Adding Pressure Gauge to Olympia Cremina"by AlexH on Wed Feb 03, 2010 10:04 pm
Yeah, 11 is not too bad, and Bar is easier but had trouble locating one. I thought omega gauges were much more expensive.
AlexH
Link to "Adding Pressure Gauge to Olympia Cremina"by TUS172 on Wed Feb 03, 2010 11:40 pm
This may be helpful...
Attaching a pressure gauge to the Olympia Cremina
I also did a pressure gauge on my 'C' Lever.
Espressme also has made a cap that can accept a pressure gauge for the Cremina.
Bob C.
(No longer a lever purist!)
LMWDP #012
TUS172
Link to "Adding Pressure Gauge to Olympia Cremina"by AlexH on Thu Feb 04, 2010 11:56 am
Espressme is Mr Penney, right?
I like your C Lever project very much btw.
My cremina is the big brass bar type. So I guess I could tap the bar and put the safety valve elsewhere on it.
AlexH
Link to "Adding Pressure Gauge to Olympia Cremina"by AlexH on Fri Feb 05, 2010 4:08 pm
I decided the quickest way to home in on correct pressure would be by taste. So I am adjusting the pressurestat until I get a good shot. Might as well trust my palate. Still too hot at this point, but starting to get good crema although burnt flavours still predominate.
AlexH
Link to "Adding Pressure Gauge to Olympia Cremina"by TUS172 on Fri Feb 05, 2010 8:29 pm
AlexH wrote:Espressme is Mr Penney, right?
Thanks the C lever as fun.
Richard Penney is the MAN!
Bob C.
LMWDP #012
TUS172
Link to "Adding Pressure Gauge to Olympia Cremina"by TheBlacksmith on Tue Feb 09, 2010 6:39 pm
I installed an Omega gauge on my Cremina. Edit... new uploaded image
Drilled into the bar, drilled a hole through the stainless front plate.
TheBlacksmith
Link to "Adding Pressure Gauge to Olympia Cremina"by espressme on Tue Feb 09, 2010 10:26 pm
Danny, that is a beautiful job of work!
-Richard
richard penney LMWDP #090,
espressme
Link to "Adding Pressure Gauge to Olympia Cremina"by TheBlacksmith on Thu Feb 11, 2010 3:27 pm
Wow, thanks for the kudos Richard. I've seen your work on the portafilters. Man! Do I want one of those!
TheBlacksmith
Link to "Adding Pressure Gauge to Olympia Cremina"by TheBlacksmith on Thu Feb 18, 2010 11:01 pm
TheBlacksmith wrote: Edit... new uploaded image
Bump for new image
TheBlacksmith
Link to "Adding Pressure Gauge to Olympia Cremina"by SwingT on Sat Feb 20, 2010 7:27 pm
Question.
Does the gauge show the pressure of the tank, or does it show the pressure that you are putting on the puck as you pull on the lever?
LMWDP #258
SwingT
Link to "Adding Pressure Gauge to Olympia Cremina"by TheBlacksmith on Sat Feb 20, 2010 10:36 pm
SwingT wrote:Question.
Pressure reading is at boiler.
TheBlacksmith
