Adding automatic false pressure release to home espresso machine?
Postby espressme on Mon Nov 19, 2007 1:42 pm
Is there such a thing as a simple retrofitable false pressure release that would allow a quicker warm up from cold for a home pro-machine? The Conti Prestina ( old simple spring lever) I have is left on 24/7 because of its huge boiler and group mass, which require a long time to change temp after release of false pressure.
Thanks
Richard / espressme
richard penney LMWDP #090,
espressme
Postby HB on Mon Nov 19, 2007 1:47 pm
Assuming you can tee into a steam line, you could add a vacuum breaker:
Chris' Coffee sells the one on the right. It resists sticking because it has a teflon sleeve and heavier pin.
Postby bobcraige on Mon Nov 19, 2007 3:24 pm
One important caution regarding vacuum breakers in home machines. Vacuum breakers work well in commercial machines that once turned on, stay on for long periods or time. In a home machine where the machine is turned on once or more a day, the valve cycles often. The more often it cycles, the more prone it is to lime build ups that can cause the valve to leak. Often this leak may be a very slow one that goes unnoticed throughout the day. This can lead to the boiler running dry unexpectedly and overheating the machine. If you are lucky, the machines thermal overheat protection kicks in and prevents damage.
The vacuum breaker is extremely convenient and really makes life easier, but there is a price to pay. That price is you need to keep after the vacuum breaker and make sure it is kept clean of deposits before it gets you into trouble.
Bob Craige
LMWDP #7
bobcraige
Postby espressme on Mon Nov 19, 2007 4:10 pm
? Does the part need to be installed vertically?
Many thanks folks,
I have looked at the photos of my machine, to check my memory, and believe there could be a "T" placed into a line from the top of the boiler at a convenient spot.
Now, whether to or not? :)
Thanks again
Richard / epressme
espressme
Postby bobcraige on Mon Nov 19, 2007 4:43 pm
espressme wrote:? Does the part need to be installed vertically?
Only if you want it to work. :lol:
Bob Craige
LMWDP #7
bobcraige
