Hey! I've had a cremina for about a week and I'm struggling to get a good shot. I replaced all the seals and cleaned the head and boiler. The lever raises as it cools, so I'm positive the seals are all good. I fashioned a steam arm pressure gauge and have it between .7 and .9 bars. I also have a superjolly, so it's not the grinder. I'm using some week old (at this point) barismo beans (highly recommended). I've read all the posts I could find on the cremina and also all the videos.
My espresso is not good. I usually overfill the basket and do a wdt and level with the top of the basket. Then I tamp, and I've been doing a hard tamp but it wasn't great so I followed some other advice and used a really light tamp. When I use the light tamp I can see some channeling. Once I did almost no tamp and I saw a giant tunnel. I do an 8s preinfusion and am sure to lift the lever until just before water comes out.
I pull a single stroke and get about 1.5 - 2oz. However, I've been pulling into 2 cups and always one of the cups is ALRIGHT and the other one has less espresso and is bitter and terrible. I'm fairly certain that it's channeling. My hard tamps don't usually show channeling, however they taste the same. On a light tamp I can see where the water hit the puck right when I lifted the lever and made indentations in the grinds. My tamps are level. Either tamp I get pretty much the same results. I really want to saw off the portafilter bottom but I have too much respect for olympia.
So my real question is, do you think my problems are water rushing in too fast? Should I lift the lever EXTREMELY slowly? I already do it pretty slowly. I'm at a loss, and I've put a pound almost of beans through. Fresh coffee is in the mail as well.
Thank you for reading my enourmous post.
p.s. i could post a video if that helps
