49mm tamper/tamping station ??
Gpinch1
#1: Post by Gpinch1 »
I currently use the original Cafelat 'Classic' tamper/tamping stand on my 58mm machine.This stand has been discontinued.
I just picked up a Cremina and would like a tamper/tamping stand specifically made for the 49mm tamper/portafilter.
Has anyone seen any other than the LWW?
grog
#2: Post by grog »
Off topic, but what year did you end up with? I recall you were looking for a used late model.
LMWDP #514
Advertisement
Gpinch1 (original poster)
#3: Post by Gpinch1 (original poster) »
I ended up with a 2016, that was used for 2 months :D
wreckfish
#4: Post by wreckfish »
That's great to hear. I don't know of a tamping station, but thought I'd pass on what I do. I have a bottomless PF, so just use a hockey puck for a tamp pad. When I use the OEM PF with spouts, I just take the basket out and fill/tamp and then reinsert. There is no retention clip in my OEM PF. Not sure if the new ones have one or not. Hope that helps.
salcangeloso
#5: Post by salcangeloso »
Ever find anything? Moving from 58mm to 49mm as well, but I'm not looking to spend another $100+ on a Lyn Weber PF holder. I emailed LW and confirmed that the 58mm is not convertible down to 49mm, so time to sell that one off and replace it.
49mmtamper.com has some ideas but I have to say I'm at a loss
HG One / '85 Cremina / Thor 49mm tamper
#6: Post by Gpinch1 (original poster) »
I went with the LW portafilter stand. Happy with it.
feitz
#7: Post by feitz »
Just in case you don't have a tamper yet:
Joe Frex / Conceptart from Germany have a 49mm stainless steel base with handle that fits the Olympias perfectly. You can choose from different handles.
Here are the links:
- http://www.joefrex.de/shop/tamper/unter ... -flat?c=24
- http://www.joefrex.de/shop/tamper/griff ... op-red?c=7
They probably sell to the US as well...
I use mine with an Olympia Club.
Cheers
Claus
PS.: I just found the US site:
- http://www.joefrex.com/about-joefrex-corp/
Best regards from Munich
Claus
LMWDP #527
Advertisement
redbone
#8: Post by redbone »
This one http://www.ebay.com/itm/Coffee-Temper-S ... SwaG9XJP7P worked out for my VAM /Caravel with similar size PF.
Semper discens.
Rob
LMWDP #549
#9: Post by Gpinch1 (original poster) »
@feitz thans for that suggestion.
I have a custom wooden Thor, which fist perfect and 2 of the Olympia tampers.
Getting one made to fit the basket makes a big difference, as far as coffee up the side of the basket after tamping.
@redbone that eBay tamper station looks good.
btw yes the new machines have a spring clip in the portafilter
feitz
#10: Post by feitz »
>>@redbone that eBay tamper station looks good.<<
I happen to have that exact same tamper base. It works very well but has a flaw: the rubber bottom on mine always comes off since the stainless steel body only rests in two grooves.
Claus
LMWDP #527
Post Reply
