This is a follow up to my dilemna.
I was able to conclude after waiting a significant amount of time, that my elements, both high and low, were not shorted. It appears that there was indeed moisture around the posts due to the material that surrounds them being melted out because of the overheating. I was really in a quandry as to how to repair it, however. Unfortunately Doug said he was going to put together a kit to do this, indicating that it was not just a matter of filling them in (see previous threads). I waited some time and tried to contact them several times, leaving messages both here in his mailboxes, and several on his site. I never got any replies. So faced with fixing this on my own or just letting it sit as parts, I read some more posts here. I do give Doug the credit as he explaiined that Barb apparantly packed a similar element with some sort of epoxy putty in one of his posts, although he did not specify what puttly she used. I started serarching the internet for the various epoxy puttys and came up with what I thought would work. It is called multi-metal epoxy, and it is available at Ace hardware. Simple enough. So I spent about $5.00 with tax and purchased a tube. I read the directions carefully which indicated that it sets in about 4 minutes. I can tell you that it really does set that fast. I filled in around all the posts and waited about 24 hours to be sure it was fully cured. I smoothed out the rough areas of putty and then replaced the ceramic insulators and wired it up again. Fortunatlely I took a picture of the wiring prior to taking it apart. I also installed a fuse. I covered the exposed wiring that was left from the fuse ends with heat shrink tubing. It turned out pretty good. I replaced the rubber bottom and then held my breath whle I plugged it into a ground fault protected socket. It started heating up to my relief, so I switched it into the high mode. As i did the rubber on one area of the bottom snaped into place and I thought the damn thing blew.
GRIN It was cooincidental that it did that as I was switching it, but it did give me a bit of a fright. I let it come to full steam, which is a little over 1 bar, and pumping steam out the relief valve, and then pulled a shot. It is just as it was prior to the meltdown, and actually better as it is now fused. I have a lot more experience as well, and I feel I know the machine better. Thank God I have my beloved Pavoni back. There is nothing like it. You lever guys know what I am talking about....THE END.
Jeff
