gitano1 wrote:I seem to recall a question about the Customer Service department a couple of months ago, but I was unable to find that thread.
gitano1 wrote:I bought a bottomless portafilter from them in June. I own a Expobar Lever and the portafilter I received appeared to be the same as the one that came with the machine with the exception being the removal of the bottom of the portafilter. When I attempted to use it I found that coffee ran down the handle and dripped on the counter. I tried various solutions to the problem including running the filter with no coffee in it. In each case the problem repeated itself.
JR wrote:I can't see how the coffee could go down the handle unless something is horribly wrong with the distribution and/or tamping--unless the cut was so bad that the opening was smaller than the filter basket. The shot shouldn't even touch the PF, much less run down the handle.
gitano1 wrote:I suspect what is happening is that that PF is making contact with the basket near its bottom allowing the surface tension of the fluid (coffee or water when no coffee is in the basket) to carry the fluid around the PF onto the handle. Ultimately, the base of the basket should be completely free from contact with the PF.
HB wrote:Below is a video of the bottomless Gaggia portafilter that Todd from WLL provided for the Achille review:
There's plenty of clearance between the basket and portafilter. Oh well, looks like the mystery of your drippy bottomless will go unsolved.
HB wrote:. . . I'm still baffled how cutting the bottom off a portafilter would produce the problem you describe.
