As RapidCoffee notes, espresso is not a roast or a blend, it is a method. The unique feature of the method involves extracting coffee at high pressures (about 9 bar). At these pressures the oils in coffee are emulsified and create what is known as crema - a foamlike suspension of emsulified oils and solids.
Here's how Ernesto Illy describes it:
"Espresso--the word refers to a serving made on request expressly for the occasion--is brewed by rapidly percolating a
small quantity of pressurized, heated water through a compressed cake of finely ground roasted coffee. The resulting concentrated liquor contains not only soluble solids but also a diverse array of aromatic substances in a dispersed emulsion of
tiny oil droplets, which together give espresso its uniquely rich taste, smell and "mouthfeel."
Here is a link to his article "The Complexity of Coffee" where the above quote comes from:
http://www.illyusa.com/pr/coffee.pdf
Here are a few other descriptions of espresso.
Francisco Illy:
"a romantic, remarkably aromatic, and complex liquid. It is at once a solution of sugars, caffeine, acids, and proteins; a suspension of tiny particles of coffee beans and minute bubbles of gas; an emulsion of oils and colloids -- all concentrated into a small volume and covered with a light, brown-colored foam known as "crema.""
David Schomer:
"a polyphasic colloidal foam made by forcing pressurized brewing water through finely ground, tightly packed coffee."
Cheers,
Ken
If not for coffee, I'd have no personality at all.
