innermusic wrote:2. Althought the taste of RO filtered water is not wonderful, it is much better tasting than the chlorinated water that comes out of my tap.
The taste of RO-water-brewed coffee is very inferior to coffee brewed using water with some minerals (50ppm+).
I plumbed in for about 4 years. Recently I moved to a place that didn't offer a convenient plumbing solution, so I bought a flojet system. Actually, I built one myself using a high-flow delivery pump and a large (2 gallon) accumulator that means that the system only re-charges once a day or less—and takes about 8 seconds to do so—but the principle is all the same: you draw from a 5 gallon bottle under the counter. In this configuration, a bottle lasts me about a week or so. I also installed a carbon filter in the delivery pump setup as well, which allows me to hold chlorinated water in the tank. I feel like this is probably a bit safer in terms of the risk of algae buildup, etc. in the bottle, feed tube, and water lines.
Using such a system is a bit of a headache compared to plumbed-in: once a week I replace the tank, formulate my water, and dump the waste bucket. But it does give me the advantage of being able to mix my water to desired TDS levels (I shoot for 100-120 ppm TDS). I mix tap water (unfliltered) with RO water. It gets carbon-filtered prior to entering the machine as I said. Before, I was using Everpure Claris. That system is great, but it was certainly related to some
annoying issues with non-scale, verdigris type buildup in my boiler which has reduced dramatically since I switched to a lower-TDS system.
YMMV, of course, but that's what I've been doing the last 5 months. I'm pretty happy with it. As an added bonus, if there's a leak or other disaster, the worst that can happen is spilling a few gallons of water on the tile floor. It'd be a mess, but better than a totally flooded house.
