On September 25, 1961, fifty years ago, Ernesto Valente filed his US patent #3,230,974, for a brew group under the title "Alternately Seating Valves" which we now know as the "E-61." The original patent can be read and downloaded HERE. Apparently, this group was designed with Faema's first pump-powered machine in mind. Before this, the majority of commercial machines were lever operated. The E-61 incorporated an infusion chamber to soften the initial force of the water delivered by the pump, and from the wording in the patent, it seems that this was an attempt to emulate the way lever machines operated.
I found the patent to be quite interesting in that the group as in use today is quite similar to that original design. Note the use of a plunger with a pin at the top of the group to clear the gicleur which in the contemporary design is protected by a filter screen. One similarity is that the original design had the infusion valve opening at 1.5 BAR, a value still used today.
Anyway, Happy Birthday, E-61. Still making great espresso after 50 years!
