Replacement Bar Cover for Knockbox
- yakster
You could try buying some tubing of the right size and thickness at a hardware store. That's probably what I'll do if mine ever needs replacing. I have the same knockbox, found it at a thrift shop.
Reading John's reply, I'd probably go with his recommendation.
-Chris
LMWDP # 272
LMWDP # 272
- JohnB.
A piece of reinforced fuel injection fuel line would probably last indefinitely. Available at any auto parts store.
LMWDP 267
I used some water tubing i got at home depot on a knockbox that was very similar to yours. Hasn't worn out since (years).
The rubber thingies at the end are replaceable by grommets used as pass through in electrical boxes...those keep getting cut through on the sheet metal though.
