Zaneus wrote:My focus ... is really is just for me personally and others to get a grasp on how different profiles affect the taste of the final cup...
You're saying that you want to see how pressure profiling affects the taste, and Jim's point is that the most effective purpose for pressure profiling will be the ability to address problem coffees. My advice is to follow
his advice since doing so will give you exactly the experience you seek.
As an analogy, try (this can be a thought experiment or a real one) changing the color balance of a pure white field in Photoshop to make it more blue. Spoiler alert: you won't get any traction since you have no color to start with that can be bent. However, if you had a photo with an overall yellow cast, Photoshop can rebalance the yellow/blue easily.
Similarly, if your coffee has really good balance to start with, the pressure controls will act more or less neutrally upon that starting neutrality. But as Jim suggests, by starting out with something that, if treated normally, will come out skewed, then your experiments with the pressure profiles will show some real effects. Some results will improve, some will exacerbate the problems, while others do nothing, and a few may run you off an entirely new and different set of rails.
Working from that basis will much more successfully highlight what pressure profiling can affect, and show you the differences you hope to see.
