Sean
lennoncs wrote:I have seen the effects of locking a cool PF on my group temp and the effect is surprising
malachi wrote:You heat the portafilter up.
Then it cools off again as you dry it.
hbuchtel wrote:I'm still not clear on what effect taking the PF away from the group head has on the temp that the coffee sees.
hbuchtel wrote:3. ? degree F heat loss in the first 5 seconds. (Andy says rapid temp drop, Barry's chart shows no change)
hbuchtel wrote:I'm thinking the next step would be to measure (how?) the effect on the temperature of the brew water (or coffee puck) as the portafilter warms up again.
barry wrote:i'm not sure the group cools significantly when the portafilter is removed... there's no doubt that heat radiates from the showerscreen, but that happens with or without the portafilter in place, so i guess for there to be significant cooldown the rate of heat loss through the showerscreen would have to increase with the portafilter removed. i'm not sure that happens.
