New home espresso bar design and set up advice wanted - Page 3
- drgary
Now I find myself in a similar situation to Ken and Michael. We'll be neighbors. I won't be in Portland but just across the river in Ridgefield, WA. Our home is swarming with contractors as we pack up our California home, which we've sold. The new home has an area that will be a coffee bar. It's across from the kitchen and formal dining room.
It already has a water line and an electrical circuit, although I guess it will need more electrical than this.
There's a laundry room behind it that will shrink, but it needs space. I expect we'll move the wall back about a foot and the coffee gear will sit against the wall. That's where I'll plumb in the Conti Prestina and install a 240v outlet for the Caravel and who knows what else in the future? The counter will be black granite to match the kitchen.
We have our own well water, and there's so much scale we can see it in the bathroom faucets. I'm now contacting people who can test our water and recommend a right-sized system, one that sufficiently purifies our drinking water and the espresso machine water supply; we'll have to see what's needed for the whole house.
Here's the hallway with the kitchen to the right.
This is the kitchen.
It gets better. My North TJ-067 1 Kg propane roaster will live in here, where there's already a workshop for doing restorations. There may be some shop equipment in my future.
We won't start on the coffee bar project until we're actually living there, but for sure I'll be asking your advice and meeting fellow Portland area coffee hobbyists. I also plan to host some get-togethers.
LMWDP#308
LMWDP#308
- TomC
That kitchen (and the rest) is absolutely beautiful. I can't wait to see it all decked out and dialed in the way you want it. I envy your new roasting digs, as you already know
- drgary
Maybe we can host you for a Portland area coffee crawl and a roasting workshop. Just let us know. The house will have a guest bedroom and there's a large office and guest space on the second floor of that outbuilding.
LMWDP#308
LMWDP#308
- doubleOsoul
Wow... the home is just beautiful. And you have an area for roasting? You must be so excited!
www.soulsidecoffee.com LMWDP #354
- keno (original poster)
Hey Gary, we'll be pretty close neighbors. I'm actually moving to Camas, WA which is also just the other side of the river from Portland. I'd definitely be interested in some get togethers so keep me posted. I arrive mid April.drgary wrote:Now I find myself in a similar situation to Ken and Michael. We'll be neighbors. I won't be in Portland but just across the river in Ridgefield, WA.
Here is a picture of my espresso bar setup in mid construction. Note that I had the builder raise the cabinet height which will give me a little over 25 inches between countertop and cabinet. The sink will be on the left and we've got two outlets on the right. I'll post more pictures when it's done.
- Martin
I'd prefer taller-than-standard counters to standard or shorter. Tamping leverage has never been an issue for my one-to-a-few shots, and, being tall-ish, I like the visual angle to see the shot pour.
Heat + Beans = Roast. All the rest is commentary.
Maybe you've already taken these clearance reducers into consideration (they don't appear in the photo) but if you have under-cabinet lighting, there is typically a 2" trim rail that extends down from the upper cabinets that helps conceal the under-cabinet lights. And don't forget the thickness of your granite, soapstone, whatever countertop materiel. I've currently got 21.5" clearance between top of counter and bottom of trim rail. So when I get that titan grinder in a few months, I'll need to spend a couple days chopping a section of upper cabinet so it is an additional 4" higher.keno wrote:Note that I had the builder raise the cabinet height which will give me a little over 25 inches between countertop and cabinet.
It's also good you're planning on storing coffee down below. The under-cabinet lights have a tendency to warm the upper cabinets.
- Maxwell Mooney
Gentlemen! Welcome to my lovely state! I would love to connect some time!
If y'all will be at SCAA, I'll be manning the Slate Coffee booth for a day and would love to serve y'all!
I definitely like white countertops as well. I'm working on installing open shelving over my coffee bar area to display nice wares and brew methods. Not sure if open shelving is an option you're considering, but it's nice for compact spaces as well.
Having good depth to work on and a built in knockbox is recommended. I find that for most things in a cafe, the pitcher rinser does as good a job or better than a sink (except washing dishes, of course). Quick rinses of shot glasses or demis, steam pitchers, etc rinsers are great. That said, their primary benefit is that of speed, which is paramount in a shop. A sink is certainly more versatile and may be a better option for you.
Your flow sounds great, but I like to put the knock box on the same side as the grinder- that way, I can brush stray grinds right into the knockbox (mine is flush mounted). This required me cutting a hole in my countertop but has been totally worth it so far.
Best of luck getting it all figured out! It's always so much fun!
"Coffee is evidence of Divine Grace, flavored coffee evidence of the Fall" -Kevin Hall
LMWDP #406
LMWDP #406
- drgary
We loaded up, roaster and all. This is our wonderful mover Stu Miller about to put the North TJ-067 onto the large shipping container that's on its way up here. He packed it tight so it's held as firmly as if it's crated.
He's about six feet tall and all of 165 lbs, but able to pull feats like this. He just picked up our washing machine and carried it over to the trailer.
We've finally arrived in WA after two days' drive towing a large trailer behind my new Forester. It was a long journey through amazing scenery and some hairy mountain passes we shared with large trucks. Now that we've unpacked our first kitchen boxes, here's my "basic" setup. My vintage machines all were in tow and will be set up again when their display area is built out. But now it feels like we're home.
We're in a small area of very nice houses but have moved from a tight-packed development into this neighborhood.* Life here will be different. We love it!
* Photo is courtesy of our friend and traveling companion, Louella Santobello.
LMWDP#308
LMWDP#308
