mivanitsky wrote:The "facts" that levers have the greatest clarity, and that narrow baskets (leave out deep - I know you are smart enough to downdose!) are no good for clarity, seem contradictory. I wonder how Kyle explained the inconsistency. Pressure profile is a copout, since levers, LMs and Synessos all can give great clarity.
It seems to me that there are multiple (2 that I see) factors at play. Lever machines (spring levers) are reputed to produce the most clarity, but they do not produce the heavy body of pump espresso machines. The reason here, as I understand it, is that they extract coffee at low pressures (I believe they tend to peak at 7 bars of pressure?). This lower extraction pressure produces shots with better clarity (more like brewed), but also less body (more like brewed also).
On the other hand, a pump machine with a small diameter brew group seems like it's going to run into issues of excessively deep pucks causing a larger differential in the degree of extraction of the top and bottom of the puck, which ultimately reduces clarity.
I don't know any of that firsthand, though--I have no experience with the La Spaziale or Dalla Corte, and most of my lever experience is with manual levers with high extraction pressures and, probably, too high brew ratios owing to my own inexperience. I'm simply presenting the plausible explanations that I have read and hoping to spark more discussion on this topic, because, for me, it's the most interesting part of this thread (as opposed to a discussion of whether clarity is desirable over sweetness, balance, and body).
