FlyingShot wrote:Ken
I'll say they're confusing - its a jungle! I had already installed a braided drain hose ready for the machine. When the tech brought the machine he said the 1/4" inside diameter would be risky for clogging. So, off to Home Depot to buy a larger hose and new fittings - big challenge is to find a reducer to connect the end of the drain hose to the smaller hose that wends its way down to the utility room drain in the basement. It must be a metric size, as a 3/4" barbed fitting is tight. I wish we could complete this 40 year transition to metric and be done with it. Anyhow, no panic, as at least the water supply is attached and the drip pan is plenty big.
Ken
I am always amused when discussing the metric system with Canadians. I do spend a week a year in Vancouver, and have done so for a couple of decades, so I have some personal experience with this.
In the US our government said decades ago that we were "going metric." The idea was that they would start slowly, like with those idiotic highway signs stating, "62 miles = 100 km," and that the rest would follow. What really happened was that the signs lasted a few years until they started to fall apart, were then removed, and never replaced. And that is as far as the "metric transition" has made it in the USA.
Canadians were more ambitious. They said they were "going metric," however they decided that what they would do is to pick and choose a few measurable things to use the metric system for, while retaining the old English measures for everything else. So, one buys gasoline in liters in Canada, measures driving distances in km, plus buys a few food items in grams, but one buys pants sized in inches, and describes their living quarters as measuring XXX square feet. Plumbing fittings are exactly the same ones found south of the 49th parallel, e.g. like in the US. The one plus is that Canada has more or less eliminated the old Imperial measures (like "Imperial Gallon") that simply didn't "work" in a country right next to one 10x its size not using any of them.
As a result, Canadians are even more confused with common measures than are Americans. Most Americans simply throw up their hands when exposed to metric measurements, whereas Canadians act like they should know what to do with them but are then not exactly sure what they mean. They are left with trying to figure out how many miles they can go on a liter of gasoline, and similar absurd computations.
Having had a scientific/medical education, and now spending 2 months a year in France, I have become equally comfortable with English and Metric measures. In fact, I prefer metric. But it becomes confusing to use more than one system simultaneously. The beauty of metric measures is that they work as a system, that one can go to measurements of length to volume to weight and back again, with an overall consistency that gives the system sense. When one picks and chooses what one will use for whatever one is measuring, as in Canada, one is actually worse off than if they had just stuck with an illogical but consistent system, such as the old English measures.
My last comment, specifically directed at espresso machines, is that espresso machines are a hodge podge of metric and English plumbing. To my knowledge, all of the commercial espresso machines use both types of fittings, in different places. How the Italians settled on this is anyone's guess. It probably shows the same type of logic as Italian attempts at electrical wiring, which anyone working on the innards of their espresso machines will soon discover.
Good luck.
ken
...split from New La Marzocco GS3 MP in the house by moderator...
